Need help wiping sdd+hdd
brownie1992
21
So i have built a new pc and in my old one i have a 120gb sdd and a 500gb hdd and i want to have them fully wiped so i can use them in my new one for storage but i have no idea how to clear them, i only know how to format them when you are installing windows again and i dont think that is the correct way
what happens to my old computer once i have done them both does it just shut off once i have wiped my ssd of windows, i am assuming i wold be doing them on my old comp or should i pop them in my new one and do it there. thanks for the reply, sorry if i am not the smartest when it comes to this thing hope you dont mind answering my questions thanks
thanks alot, i will connect the old drives after i install windows on my new sdd and wipe them then if this is the correct way
Thanks again, it is early hours where i am and i will be putting my new computer together as soon as it hits light, one last thing though, after i install windows on my new sdd when i connect my old drives will they just show up in disk managment and do i simply right click and format? they both only have 1 partition or one big one so i just need to format and i am all good they will be clear and fresh?
