Hey gracious helpers! I have never built a computer before, and I wanted to build an audio production PC with a budget of $1000. Is there anything I should be wary of as a first time builder?
APPROXIMATE PURCHASE DATE: June 13 - 22 BUDGET RANGE: $1000
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: audio production (sonar, reason), I also want to be able to play left 4 dead and starcraft 2.
PARTS NOT REQUIRED: USB Mouse, keyboard, speakers, 19" screen, audio interface
PREFERRED WEBSITE(S) FOR PARTS: no preference. There is a Fry's Hardware about 15 minutes from where I will be for the next month though.
PARTS PREFERENCES: I would like to have 6 - 8 GB of memory with as much cpu as possible.
OVERCLOCKING: Yes (I've never done it, but I think I am capable of following a guide. Are these parts good for overclocking and getting my money's worth?) SLI OR CROSSFIRE: Maybe?? I don't know a lot about this.
MONITOR RESOLUTION: 1280x1024
ADDITIONAL COMMENTS: Reasonably quiet
Here are two builds I have looked at so far. Also, I am wondering about AM3 and DDR3?? Should I be getting an AM3 Phenom II with DDR3 compatible motherboard and DDR3 RAM instead?
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151188
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131381
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157156
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102824
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703009
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220353
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103471
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003
SAMSUNG DVD Burner Black SATA Model SH-S223L - OEM
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail
ASUS M4A78 Plus AM3/AM2+/AM2 AMD 770 ATX AMD Motherboard - Retail
ASRock A790GXH/128M AM2+/AM2 AMD 790GX HDMI ATX AMD Motherboard - Retail
SAPPHIRE 100245HDMI Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
PC Power & Cooling S75QB 750W ATX12V / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Power Supply compatible ... - Retail
Arctic Silver 5 Thermal Compound - OEM
Patriot Viper 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Desktop Memory + 2GB Xporter Razzo USB w/Futuremark 3DMark ... - Retail
AMD Phenom II X4 940 Deneb 3.0GHz Socket AM2+ 125W Quad-Core Black Edition Processor Model HDZ940XCGIBOX - Retail
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler - Retail
Nippon Labs 15 ft. USB2.0 A/male to B/male cable Model USB-15-AB - Retail
Total price $734 rebates to $640
The other computer I "made" on the HP website was this one -
m9600t series total price $899
# Genuine Windows Vista Home Premium with Service Pack 1 (64-bit)
# • Intel(R) Core(TM) i7-920 processor (2.66GHz, 1MB L2 + 8MB shared L3 cache with QPI Technology)
# • FREE UPGRADE! 6GB DDR3-1066MHz SDRAM [3 DIMMs] from 3GB
# • FREE UPGRADE! 640GB 7200 rpm SATA 3Gb/s hard drive from 500GB
# • 512MB ATI Radeon HD 4350 [DVI, HDMI, VGA adapter]
