I do not have specific games in mind, really. Pretty much any games that will be on the market on future for streaming.
Approximate Purchase Date: e.g.: Within a month
Budget Range: Total of $1500, but less the better.
System Usage from Most to Least Important:
Main purpose is to game, stream, and video edit
Are you buying a monitor: Yes
Overclocking: Was not going to, but AMD Ryzen series looks OC friendly. So will look up for videos or websites for optimized and safe OC.
SLI or Crossfire: Mostly no. Learned the pain of SLI hard way..
Your Monitor Resolution: Thinking about getting 1920 1080, but also considering 1440 resolutions
Additional Comments:
https://pcpartpicker.com/list/F8bvFd
I tried to do it on my own, but Ryzen still seems to need a bit more time to be "stable".
So I wanted to ask if anyone can suggest stable system and hardware.
My main concerns are
1. 1600 vs 1700 - Because $100 can make some room for other hardwares.
2. Motherboard manufacturer. Heard Gigabytes do good job, but Asrock as well.
3. 1070 or 1080. The difference in their performance was quite significant.
If going 1070, which manufacturer would be good? Trying to go for white/blue theme.
4. monitors. Do you really need 144hz monitors or 1440 resolution to stream on 1080p?
Thank you for your help in advance.
Trying to go for white/bluish theme, but color is not the main concern.
