need help with 3 componets, cpu,mobo,ram
Majestera
602
im looking to upgrade my current system, i have a 750ti sc gfx card
500w psu
atx/micro atx case
2 1tb hdds
i need Mobo, cpu and ram
ill upgrade my gfx card later.
budget is 400$ can someone send me some options?
i would like the best bang for the buck and perfer AMD cpu
You can go for these:
CPU: AMD - Ryzen 3 1300X 3.5GHz Quad-Core Processor ($128.69 @ OutletPC)
Motherboard: MSI - B350M PRO-VDH Micro ATX AM4 Motherboard ($68.89 @ OutletPC)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-2666 Memory ($189.88 @ OutletPC)
Total: $387.46
Generated by PCPartPicker 2017-12-30 05:15 EST-0500
Few words
Ryzen 3 1300X is the best value CPU when it comes to the Ryzen CPU family.
While you can go cheaper on MoBo, this is the cheapest MoBo that has 4 RAM slots for easier RAM upgrade in the future.
I also added...
Total: $387.46
Few words
I also added 16GB of RAM which is more than enough to play today's games. You can also go cheaper on RAM and get 2133 Mhz RAM but you'd loose RAM performance due to this.
