Question Need help with 3DMark score
ridwan123
226
22
585
I just benchmark my GPU rtx 4070 super using time spy and i only get 20300 point .according to the average it says 21000 and i just missed 800 point.why this is happening
GPU : ZOTAC TWIN EDGE OC WHITE EDITION 12 GB 4070 SUPER
CPU : I7 14700F
PSU : MONTECH 850W 80+GOLD CENTURY G5
RAM : CORSAIR 6000 MHZ 16×2 RGB
MOBO : Z790 GIGABYTE GAMING X AX DDR 5
What problems, if any, are occurring?
Could be some + or - differences in both the average value 21000 and/or the system's benchmark value 20300.
The 700 point difference (21000 - 20300) rounds to a 3.3% difference. Likely to vary from one test to the next.
If the system is performing well then leave well enough alone.
CPU : I7 14700F
every time you get a benchmark score it will never be the same as the previous one
There's no fixed score to compare to. The average always changes because everyone's comparing to each other, not a fixed reference. Kinda like player vs player, instead of player vs bot.
The score changes with the different power limits between cards, and the boost clock also changes every 5C or so(IDK the exact number). Best scores are usually the first run, in the mornings/evenings instead of afternoons, in air conditioned rooms, and the cooler seasons.
Reactions: CelicaGT
