[SOLVED] Need help with 600 euro build
rob.green615
Commendable
Dec 1, 2018
19
So my 5 year old PC is giving up on me so I'm looking for a new build.
I can use these from my old build:
Corsair PSU CX750M
Cooler Master Elite 310 - Mid tower - ATX
Cooler Master Hyper 212 EVO - 120 mm
Crucial M4 128GB 2.5" SATA600 Slim
Seagate 1TB 3.5" SATA-600 7200rpm 64MB Barracuda
I'm planning to buy it ASAP. Willing to pay around 600 or if extra 100 makes a significant difference then nothing's broken. Primarily use it for internet, movies and games.
I'm living in Ireland so I want the parts to be available in Europe. www.mindfactory.de would be a good option unless there's better prices elsewhere.
I will not overclock or upgrade it in the future.
AMD Ryzen 5 2600G - 160.-
MSI B450M Gaming B450 So.AM4 mATX - 82.-
8GB Sapphire Radeon RX 580 Nitro - 250.-
8GB Patriot Viper 4 Red DDR4-3000 - 62.-
Would this work?
Any help is much appreciated!
Oh yeah, BeQuiet is a very good German brand. That's a good one. I found it cheaper on Amazon:
https://www.amazon.de/dp/B01MS8EX0W/?tag=pcp05-21
BTW, this is the one I was talking about:
https://www.amazon.de/dp/B01MDVJDIK/?tag=pcp05-21&th=1
Other decent options are these:
https://de.pcpartpicker.com/product/nB3RsY/seasonic-power-supply-s12ii620bronze...
Ryzen 5 2600G? I think you typed this wrong.
I would suggest getting a motherboard with 4 RAM slots so you can get a 2x4Gb instead of 1x8Gb of RAM. This works much better. (Keep in mind that I don't mean: buy two 4Gb RAM sticks. Get one 8Gb box containing 2 sticks of 4Gb of RAM)
I think I'm gonna be fine with 2 RAM slots because, will keep it only for a year or two.
I'm a bit paranoid about using my current PSU because computer is doing random shutdowns so I will buy a new one just in case...
Would 450W be sufficient to supply this system?
https://de.pcpartpicker.com/product/B6XnTW/cooler-master-masterwatt-550w-80-bronze-certified-semi-modular-atx-power-supply-mpx-5501-amaab-us
Or if you're just gaming a little bit on the weekends, the CX450 you originally picked could work, but you would be cutting it close as it's not recommended if you're gaming.
