Well... I've bought an EVGA 2Gb GTX680 recently, and I went to install it in my rig of -
AMD fx4170 4.2Ghz
Gigabyte GA 78LMT-USB3
Artic MPS550 550W
former GPU (problem) MSI 7770 1Gb
And so forth; I deleted the old GPU's driver as it told me to in the EVGA manual, I disconnected everything, got ready for the swap & put in the 680, only to realise I didn't yet have the 8 pin connector, so I unplugged it after an attempt to find enough connectors to make one, and re-installed my 7770 & my pc refused to load up the login screen, it just says "Input not support" can you guys help?
AMD fx4170 4.2Ghz
Artic MPS550 550W
