Need Help with ~800 AMD Build
nave_
33
Hey guys,
I, like so many people here recently, have decided to taken it upon myself to build a new gaming computer. Here is the list of things I have:
CPU: AMD Phenom II X4 955 http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
MoBo: Gigabyte GA-990FXA-UD5 http://www.newegg.com/Product/Product.aspx?Item=N82E16813128509
RAM: G.Skill Ripjaw series 4gb http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
GPU: GTX 460 http://www.newegg.com/Product/Product.aspx?Item=N82E16814130568
Hard drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136795
CD/DVD: http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
I need help choosing a nice case as well as a powerful enough powersupply to power gtx 460 in sli and the new processors by AMD.
I guess my main concern was getting the 955, a cheaper processor, so I can upgrade to Bulldozer in the future. Any suggestions and tips are appreciated
Thanks!
nave_
33
What would be the rationale behind that?
Also, is it smart to get the 955 and upgrade the cpu later when bulldozer is released? or should I just go ahead and get the i5 2500k?
browsingtheworld
612
Get this video card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500206
GTX 560 non-Ti for $170 shipped plus rebate. Best card for the price, faster and cheaper than what you picked out.
You really should go with an i3-2100 + LGA1155. It'll be much faster in games than what you picked out and use significantly less wattage (60W). In fact, the i3-2100 is faster than AMD's fastest chip, the Phenom II 980 BE:
http://www.anandtech.com/bench/Product/362?vs=289
Look towards the bottom for games.
PSU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817815007&Tpk=xigmatek%20400w
I would wait until the end of August personally for an AMD build. I think AMD is a solid route, just it can't compete with Intel right now. At the end of August, that is the expected date for BD to arrive. Course details will be released the 24th.
http://www.guru3d.com/news/amd-uncovers-bulldozer-details-on-august-24th/
If you can't wait I can understand since it is a while.
addison
621
Browsing the world, what happens if he OC the 980 BE also you should see the new AMD cpu, I bet you ati new series will be top line the 5000 series had like x2 more sales than the 200 series.
browsingtheworld
612
Still allergic to grammar I see.
The 980BE costs much more than the i3, I was just using the benchmark to show the i3-2100 will beat a Phenom II at 3.7ghz. If he were looking into spending that much on a CPU he can get an i5-2400 which will destroy any Phenom II on water or air.
