Need help with 9700pro
Civilized
753
I have a sapphire radeon 9700pro.....a fan I had epoxied on fell off yesterday and took a capacitor with it.....it broke the little capacitor arms off so I need to buy one to replace it and solder it back on in the lab....
Does anyone know the specs on this capacitor
it is the capacitor on the bottom left side of the board (the side away from the agp slot).....it is the one in the upper right corner of the group of capacitors in this corner.....it says the following on the capacitor
A28
470
6.3V
what do these mean and where can I buy one?....I hope I can repair this pretty easily because it has nice solder points to work with and hopefully I can do this....
can anyone give me some advice?
THanks!!
Also what would happen if I tried to boot without this capacitor?...im not going to just curious
<A HREF="http://dnadesignz.kicks-ass.net" target="_new"><b><font color=green>MY SYSTEM</b></font color=green></A>
BirdRobin
277
Do u have a picture?
Poor thing. U mean u epoxied the fan to the capcitor?
Athlon XP 1800+ 1.52ghz
Gigabyte GA-7VKML
Powercolour R9600pro Bravo @ 480/340
128+256 DDR266
Maxtor 20gb 7200rpm 2mb, WD 40gb 5400rpm 2mb
Creative SB Live! 5.1 Digital
Civilized
753
actually I was epoxying a orb cooler onto my 9700 when it was out of my system and it fell off and took out a capacitor....it looks like it would be an easy one to solder back on if I could figure out what kind of capacitor it was and where to get one.....I will take pics or find one
thanks
Civilized
753
I have a picture of the capacitor and its location if anyone here has any electrical knowledge....all I need is where to get one of these so I can replace it.....help would be greatly appreciated
Thanks!
if you would like to see the pic give me your email and I will send a pic
