Need Help With A $800 Gaming PC
vpott112
Hi, I'm looking to build a nice gaming computer pretty soon but I mainly want to focus on great performance, upgradability, reliability. It would also be great if I could run modern games on Ultra settings. Thanks in advance!
P.S - This is my first PC build so go easy 😉
Here is a Good system for you, Close to the system i am currently using, just a bit downgraded on the CPU, PSU, And GPU (Same series, just lower power I guess)
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($209.75 @ Vuugo)
Motherboard: Gigabyte GA-H97M-D3H Micro ATX LGA1150 Motherboard ($99.99 @ NCIX)
Memory: Kingston 8GB (2 x 4GB) DDR3-1600 Memory ($99.25 @ Vuugo)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($58.75 @ Vuugo)
Video Card: MSI GeForce GTX 750 1GB Video Card ($129.99 @ Newegg Canada)
Case: Zalman ZM-T1 MicroATX Mini Tower Case...
PCPartPicker part list: http://pcpartpicker.com/p/w8RrP6
Price breakdown by merchant: http://pcpartpicker.com/p/w8RrP6/by_merchant/
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor ($168.99 @ NCIX US)
Motherboard: Gigabyte GA-B85M-DS3H Micro ATX LGA1150 Motherboard ($55.98 @ Newegg)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory ($62.99 @ Newegg)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive ($54.99 @ SuperBiiz)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($52.85 @ OutletPC)
Video Card: Sapphire Radeon R9 290 4GB Tri-X Video Card ($278.99 @ SuperBiiz)
Case: Corsair Graphite Series 230T Black ATX Mid Tower Case ($57.99 @ Micro Center)
Power Supply: SeaSonic 620W 80+ Bronze Certified Fully-Modular ATX Power Supply ($54.99 @ Amazon)
Total: $787.77
Generated by PCPartPicker 2015-01-05 11:36 EST-0500
Hope this helps :)
Case: Zalman ZM-T1 MicroATX Mini Tower Case ($31.31 @ DirectCanada)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply ($49.98 @ Newegg Canada)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer ($17.75 @ Vuugo)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit) ($108.34 @ TigerDirect Canada)
Total: $805.11
Generated by PCPartPicker 2015-01-05 11:47 EST-0500
Will run ultra if you are playing at 1280x1024, Wont run 1080p ultra, Maybe medium high @ 1080p, But anything under that you should be okay
EDIT: The price range you are wanting at is hard to get a highend gaming rig that you are wanting (if thats what your looking for) This system will be a great start for you, and will allow any upgrade possible, you can even get a full size case and use the microatx MOBO in that if you like.
EDIT2: I would wait till windows 10 comes out. As if the rumours are correct, It should be free. Then you can spend the extra 100$ towards the GPU or something.
