Question Need help with a AUD$1700 build
Lucaz_70
Commendable
Mar 14, 2017
55
I need help with a build, pretty self-explanatory, id like a GTX 1080TI or an RTX2070 if possible, I really don't know too much aha.
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor ($195.00 @ Shopping Express)
Motherboard: ASRock B450M-HDV Micro ATX AM4 Motherboard ($99.00 @ Umart)
Memory: GeIL EVO SPEAR 16 GB (2 x 8 GB) DDR4-3200 Memory ($118.80 @ Newegg Australia)
Storage: Crucial MX500 500 GB 2.5" Solid State Drive ($92.90 @ Shopping Express)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive ($149.00 @ Umart)
Video Card: Gigabyte GeForce RTX 2070 SUPER 8 GB WINDFORCE OC 3X Video Card ($839.00 @ IJK)
Case: Cooler Master MasterBox Lite 3.1 MicroATX Mid Tower Case ($62.00 @ Skycomp Technology)
Power Supply: Antec Earthwatts Gold Pro 650 W 80+ Gold Certified Semi-modular ATX Power Supply ($129.00 @ Scorptec)
Total: $1684.70
Generated by PCPartPicker 2019-10-03 01:10 AEST+1000
Newtonius
Upstanding
Sep 25, 2019
391
73
290
24
So here's a list of things you'll need to get, I'll also throw in some key words for you to search for (because I can't pick everything out for you plus I don't know what sales are going on in your region):
CPU:
Intel or AMD brands are your only options.
For Intel: i7 7700k, i7 8700k, i9 9700k
For AMD: Ryzen 7 2700X, Ryzen 5 3600, Ryzen 7 3700x
These would fit your budget and are recent enough to perform well. The order goes from oldest to newest.
CPU COOLER: (this can be determined once a cpu has been chosen)
MotherBoard: (also requires a cpu to be chosen first)
GPU: I'd say go with a 2070 Super (~750AUD)
RAM: (Anything DDR4 between 2666Mhz and 3600MHz)
Storage: (a small 250GB NVMe for OS) and a 1 - 2TB HDD for storage and games
Power Supply Unit: (Anything 600W would be ideal for a 2070 Super, just don't cheap out on your Power supply. That's a big no no in the pc building world)
Case: (will vary depending on Motherboard and Power supply choice)
So just fill out or ask questions about each option as you progress and you should have yourself a custom build. You can use a website like pc part-picker to choose each part. https://pcpartpicker.com/ Just look for the items with the keywords I used in each section.
Lucaz_70
Commendable
Mar 14, 2017
55
CPU:
i may have lied a tiny bit, ik that you shouldn't cheap out on ur power supply haha, but I've looked into the rtx cards and the SUPER cards don't give a big improvement for their price, there might be a better alternative, but thanks alot
