Question Need help with a case asap, please! Inter-Tech S-3906 Renegade
Feb 25, 2020
Hello everyone so today I finally got my case (waited 4 weeks) after the install I have a problem the front RGB panel and the fan led doesn't work.
The case https://www.pcgarage.ro/carcase/inter-tech/s-3906-renegade/
The motherboard https://www.pcgarage.ro/placi-de-baza/gigabyte/ab350m-ds3h-v2/
I don't know if it's a case problem or a compatibility witch one is bad or not, I don't wanna send it back and went 4 more weeks tho if It's broken got no other option.
I will put some photos so you can see what is what.
Photos: View: https://imgur.com/a/SQTXJmF
Feb 25, 2020
Did you connect the controller to the motherboard's RGB header?
Have you followed the instructions on page 4 here?
https://www.inter-tech.de/en/support/downloads/misc/1659-manual-s-3901-s-3906/file
Have any of the connections come loose in transit? e.g. the fan or RGB strips that are meant to be connected to the controller?
Yes I did, I have put the PWM at my sysetm fan and nothing, When I press the switch button nothing is happening the case fan is working but his RGB and the case RGB aren't.
Mtop
Proper
Nov 21, 2019
168
14
115
Have you enable the led mode?
Last item pg 4 you hold the fan button down 1 sec=turns leds on, 4 seconds gives control to MB 6 seconds = turns leds off.
Feb 25, 2020
Yes I did Hold the button for 1 sec for 4 for 6 for 15 for 2 for 20 used even a timer and nothing happening.
I really don't know what else to do, the XWD connector is a 5v 3 pin digital but I dont have a slot for that. and no idea what motherboard has one. (A good gaming one tho). or if it's the case problem.
