Hey Everyone,
I am looking to add LED light strips to my motorcycle. I have found these, which are fine for what I want, and the switch:
Lights
Switch
The lights are 12v, which means I am good to hook it right up to the battery. What would be the best way of doing this? Basically have the 4 +/- wires coming from the lights, the switch to turn them on and off, and need to run the power off the battery. Would a simple fuse box be the best option, and what's the best way to wire the switch to cut power?
Thank you in advance!
Lights
Switch
