Approximate Purchase Date: Might be in a week from now.
Budget Range: Around $600.
System Usage from Most to Least Important: Gaming, editing videos, surfing the internet, watching videos and movies.
Are you buying a monitor: No.
Parts to Upgrade: CPU, motherboard, RAM, GPU, power supply, case.
Do you need to buy OS: No.
Preferred Website(s) for Parts: Whichever has the cheapest part.
Parts Preferences: by brand or type: Whichever is quieter.
Overclocking: No.
SLI or Crossfire: No.
Your Monitor Resolution: I have two monitors with resolutions of 1920x1080, and 1440x900.
Additional Comments: I would like a very quiet PC. My old PC was way too loud. I will also use it for editing videos. I don't do any commentary, just record the games and edit them. I want to run current gen games at a decent framerate, and I also play a lot of games on emulators. I heard emulators were CPU intensive, so hopefully the processor I chose can handle it. I also heard video editing runs faster with more cores, so I tried to go with an 8 core CPU. AMD is the only affordable option. Intel prices are too high for me to handle just yet with my budget.
I asked before when I needed help with a $500 build. I had great help, but my budget went to around $600 now. I kept some parts from the $500 build and upgraded other parts.
I'm thinking of getting the Ripwjaws X ram sticks since it's cheaper and has a combo discount. I was worried if the Cooler Master Hyper 212 EVO can fit since I heard it can go over the ram, and the ram sticks have those long fins on the top.
I had a question before adding the case to my pcpartpicker list. The Rosewill galaxy-01 has two variations. One has blue LED and the other has red LED. the red version seems to be a little wider but not by much at all. The red version is also $5 cheaper according to pcpartpicker, but on the site it shows it as the same price as the blue version. Should I go with the red version for now, unless I'm missing some obvious difference, which I usually do 🙁 I also like red LED's more haha
Here are both versions of the case:
http://www.amazon.com/dp/B00E0P7JFA/?tag=pcpapi-20
http://www.amazon.com/dp/B00GGGIQBM/?tag=pcpapi-20
[PCPartPicker part list](http://pcpartpicker.com/p/CsCfD3) / [Price breakdown by merchant](http://pcpartpicker.com/p/CsCfD3/by_merchant/)
Type|Item|Price
**CPU** | [AMD FX-8350 4.0GHz 8-Core Processor](http://pcpartpicker.com/part/amd-cpu-fd8350frhkbox) | $149.99 @ Amazon
**CPU Cooler** | [Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler](http://pcpartpicker.com/part/cooler-master-cpu-cooler-rr212e20pkr2) | $26.92 @ OutletPC
**Thermal Compound** | [Arctic Cooling MX4 4g Thermal Paste](http://pcpartpicker.com/part/arctic-cooling-thermal-paste-acmx4) | $6.29 @ SuperBiiz
**Motherboard** | [Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard](http://pcpartpicker.com/part/gigabyte-motherboard-ga990fxaud3) | $93.00 @ Newegg
**Memory** | [G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory](http://pcpartpicker.com/part/gskill-memory-f314900cl9d8gbxl) | $82.99 @ Newegg
**Video Card** | [Sapphire Radeon R9 280 3GB Dual-X Video Card](http://pcpartpicker.com/part/sapphire-video-card-100373l) | $164.99 @ Newegg
**Power Supply** | [XFX TS 550W 80+ Gold Certified ATX Power Supply](http://pcpartpicker.com/part/xfx-power-supply-p1550gts3x) | $62.99 @ Newegg
| | **Total**
| Prices include shipping, taxes, and discounts when available | $565.17
| Generated by PCPartPicker 2014-11-23 23:15 EST-0500 |
Thank you very much for the help!
Overclocking: No.
Type|Item|Price
| | **Total**
