Need help with a Gaming PC
Xallium
Hey, I haven't had a computer since I was a child, so I've decided to get back into it, and go into gaming and such.
I've been quoted this
MotherBoard - Asus Z87 149.99$
Thermaltack Case - 49.99$
Win HP 7 64BIT - 95$
Power Supply T/T TR2 TR-600P 600W 80 Plus Bronze 59.99
DVD-RW LG 19.99
Hard Drive WD Sata 6G/S 64M 87.99$
CPU/Intel i5-4570 Q-Core s1150 3.2g 6M 213.99$
Memory/Kingston -16G 139.99$
Video Card - Gigabyte GV-N760 OC-2GD 289.00$
total 1250ish $CAD
is this worth it? is there anywhere I can upgrade or swap with a better option, 1300$ is my budget.
Without knowing the specifics, it is hard to tell you one way or another. For example, which Asus Z87 MB? What type of Thermaltack case, etc.
I always check Newegg and typically purchase from them since they are usually lowest price.
