I built my friend a new computer a couple of days ago, and I am still trying to work all of the bugs out of it. I am using Foxconn G31MV-K LGA 775 motherboard with onboard graphics, and I am using a 30" LCD tv as the monitor. The problem occurs after I install the vga drivers off of the disc, or from the website, after I restart the computer it will get to where Vista has the bar going accross the screen, then when it should show up the login screen the TV goes black and has not support in the top right corner. If I don't install the vga driver's it works just fine I have even tried at the lowest possible resolution 800x600. I don't believe the TV is 1080p I think it is 720p and I am hooked up by RGB cable (VGA). Any help would be great!
