First of all I would like to say hi to everyone and I have several questions regarding on the PC I plan to put together.
The parts I plan to use can be found below:
CPU: AMD FX X8 9590 4.7 ghz 16 MB Cache
Motherboard: Asus Crosshair V Formula Z 990FX
SSD: Samsung 540 GB 840 EVO SATA 3.0
PSU: SEASONIC X-Seriesi (SEA-X-1250) 1250Watt APFC 80+ Plus GOLD
RAM: Corsair Vengeance Pro 16 GB 2400 Mhz DDR3
Graphics Card: Asus GTX980 ROG STRIX OC GDDR5 4GB 256Bit DX12
Computer Case: Corsair Graphite Serisi 780T Beyaz Full Tower
My purpose it to just play games and fps drops aren't that important for me.
Now I don't want to overclock the CPU, so do I still need to buy a liquid cooling solution (Corsair H110)? Or would a Zalman CNPS12X be enough for it?
Also, can I just overclock the RAM to 2400 mhz and not the CPU? When I overclock just the RAM would I have stability issues?
Another question I have is about the compatibility of the motherboard and the CPU because normally it says 140 w and CPU requires 220w. I just wanted to know about the topic from people who use it if they have experienced any problems.
My last question is how is the temperature of 9590 in a normal state (without overclocking) while playing games?
Like I have said I just want to play games and FPS drops aren't that important for me.
The reason I plan to use GTX980 is because in the future (1 year later) If I plan to change my system at least I won't have to worry about buying a new graphics card.
I would appreciate your support on the topic.
Thank you.
Thank you.
