Need Help With a Point 2 Point Question.
Apr 6, 2018
5
I bought 2, NanoBeam 5AC Gen2 Point to Point Antennas I have about 300 feet to my place that needs internet. After I get them set up and ready to be mounted, in the building I need internet can I use a Wireless apple router and just plug the Ethernet from the Antenna into the Router and have wifi and then just use it like i would at my main house or do I need a AP or Modem?
No that should work, if you plug it into the WAN port of the Apple router you will create a second network, if you use the Apple router in AP mode (check guides on here on how to do this) you will be on the same subnet as the main building and will be able to communicate with the other devices.
