alright so i want to get another graphics card (i already have a rog strix geforce 2080ti oc edition) and im just looking for another since i do heavy graphic design. however i have a few things i was told that i need clarified.
1. i was told by a friend who built his computer a few years ago that i would need to get a bigger cpu fan and more case fans. I am currently employing the use of a Corsair H100i platinum rgb 240mm aio liquid cooler and the case fans are thermaltakes riing 3 set that come with the case i bought, the thermaltake view 71.
2. i was told by someone at the microcenter when i went for information. that you dont need more than half an inch of room between your graphics cards, i have a z390 aorus pro wifi gaming motherboard. and if i do actually need a lot of room between them then thats going to be an issue ill need help with
here are some images to help
the whole build View: https://imgur.com/hKNu1aJ
the only other place i could put a graphics card View: https://imgur.com/ueipQSZ
there is one space under it but it might hit the power supply.
