The problem have been here for quite a long time, but I just decided not to stand it anymore. My pc is a Acer Aspire E1-772G, with a internal Nvdia 820M. However, whenever I use the NVDIA, everything on the screen seems crushed with tiny lines all over the screen. When I use Intel HD graphic, everything is fine despite the low performance. (As seen as the following Minecraft Gameplay Captures)
I've already re-installed my NVDIA drivers for like thousands times but it showed no help. I've tried DDU, also no help.
There is one point I would like to point out that back in the days I used Ubuntu, the NVDIA card worked completely fine. (Before I switched to Ubuntu, I was also using Windows 10)
More screenshots:
Currently Running Windows 10.
Thank you very much, your help are much appreciated.
More screenshots:
