Hi,
I just recently bought a customized pre-built computer from Cyberpower pc. I have built my own computer before, nothing crazy. But this time around I wanted it to be hassle free.
I am completely new to watercooling/aios. I didn't know that AIO was a thing until a few weeks ago. I decided to go with the Kraken m22 with a push pull configuration on the back of my case to cool my Intel i7-8700k. I also have two frontal case fans. I have the ASUS TUF H370-PRO gaming motherboard.
When I first turned on the computer the fans were very loud so I was wondering what was going on so I did some googling. For some reason they only connect the fans directly to the power supply with molex connectors so they can't be controlled?
There was only 1 fan connected to my motherboard chassis and the pump has its own plug. So the CPU fan 4 pin was completely empty.
I want the fans to speed up when my CPU heats up, but also not be full blast at all times. Just idling on the desktop it was on full blast before.
I connected the 2 front fans and the 1 fan on my radiator that wasn't connected to the motherboard to the motherboard via 4 pin connectors.
I only have 2 chassis fan headers so I just ordered some splitters from newegg hoping they may help.
I plugged my two frontal fans into a chassis header and then other one into the back of it with a molex since I do not have enough fan headers. And the other fan on my radiator into the CPU Fan spot since there was really no where else to put it. I know this isn't ideal.
My question is where should I plug the fans on my radiator to?
To the motherboard or am I better off hooking them up to the power supply and dealing with the noise? I am kind of picky about it being quite.
I believe the Kraken m22 comes with 1 NZXT fan so should I hook that up to the CPU_fan spot since the pump has its own hookup? And then the other fan onto a chasis fan header and then splitting the front 2 fans?
I installed the Asus Fan Xpert and I have been playing around with it. Right now it was the CPU fan at 550rpms, Chassis fan 1 at 400ish, and then chassis fan 2 at 1800rpms. Pretty big difference. The AIO pump is around 2100 and all of this is while idling.
I'd love some feedback even if no one has a clear answer. I don't really know anyone to ask and I have been here before lurking for PC help before and I am hoping this will give me some insight! Please ask any questions!
Thanks in advance!
Thanks in advance!
