Hi!
I am planning on buying a Corsair iCUE 465X and a Corsair H100i RGB Platinum AIO cooler.
When I first picked out these parts, I initially wanted to mount the AIO at the top. After some research and watching YouTube videos on the case, I found out that the AIO (or any AIO for that matter) would not fit at the top of the chassis as the RAM sticks obstruct space not leaving enough room for both the radiator and the fans (only one or the other). This was an annoying inconvenience that I actually have seen in other Corsair cases I’ve considered buying. Why is Corsair restricting the space at the top so much? It’s a mid-tower case...
Anyways, a solution I’ve thought of was to unscrew the fans on the AIO, mount those fans at the top (where I originally intended to mount the whole AIO) and then mount the radiator itself in the front of the case behind the 3 pre-installed rgb fans that come with the case.
Would this solution work? This might be a dumb question because I’ve seen many people use radiators on the front, I am aware it’s very common, but this is my first build and I don’t want to mess anything up, so I’m going to be super cautious, especially with stuff that isn’t even mentioned on the manufacturer’s website. Corsair’s website says you can fit a 240mm AIO, which you can, but it doesn’t specify that you will only be able to at the side...
Anyways, if anyone could help me, that would be really great.
Thanks!
Thanks!
