Hi! I just replaced the noisy stock cooler for the AMD FX8350 (max temp in full load was 65°C/149F) but with the newly installed silent Cooler Masters Hyper T4 in full load raised like 10°C/18F. That is a lot. Video card temp is perfect, never had problems.
I have only 2 fans installed on my case out of the 6 slots. I attached a pic with the the rig and current fan positions. I want to buy one or two fans, hopefully this will solve the problem.
Specs (not sure what matters and what not so here is all i know):
MB: Asus M5A97 Evo
CPU: AMD Fx8350
GPU: Gigabyte R9 280X
HDD: CAviar Blue 1tb
DDR: 8gh HyperX Blue 1600 (2x4gb)
Case: Chaser A21
Fans: One is stock from case and the other one is Enermax Silent Fan.
CPU Cooler: Cooler Masters Hyper T4 Positioned from bottom to top.
Please take a look at the picture and tell me where should I install one or two new fans to improve airflow to the CPU and make it cooler.
http://i280.photobucket.com/albums/kk192/radu191289/airflow_zpsdaa8172c.jpg~original
MB: Asus M5A97 Evo
CPU: AMD Fx8350
Case: Chaser A21
