Hello people, I am mainly posting this because this is my third (!) Corsair H115i to fail (1. pump failure, 2. liquid clogged, 3. liquid is about to clog or there is air inside, temperature increase).
I let a shop build my pc and they are now sending me an NZXT Kraken X62 instead (they said they have made good experiences with it and use it a lot).
This is my current airflow setup:
View: https://imgur.com/a/1zco4Wy
I got one intake fan in the front, one exhaust in the back, and two on top of the radiator pushing air through the fans as intake - they are controlled via an Aquaero 6 LT.
This should create positive pressure, right? I feel like the dust still builds up inside the case (especially on the back part).
My components are:
Phanteks Enthoo Luxe Case (I can only mount the 280mm radiator at the top)
Asus Maximus IX Hero
Intel i7-7700k 5.1 Ghz @ 1.392v (delidded)
Asus Strix 1080 ti OC
Now I got two questions:
What improvements in the air flow can you guys recommend?
Is it normal an AiO fails 3 times on me?
Thank you for helping!
My components are:
