Question Need help with ARGB fan connection
Irfan.ahmed
40
I have below components in my pc setup.
DEEPCOOL CASTLE 360 RGB V2 360 MM CPU LIQUID COOLER that comes with
  • 3 120mm ARGB fans
  • A fan hub that can connect upto 4 fans.
  • One ARGB Hub that allows upto 5 ARGB fans(both 3 pin and 4 pin)
ASUS TUF Gaming X570-Plus (Wi-Fi) Motherboard
- Has only one ARGB header
MATREXX 55 MESH ADD-RGB 4F PC Case
- Comes with 4 pre installed 120mm ARGB fans. 3 in front and 1 in back)
I have installed the Radiator in front and used all the 4 pc case fans to connect to fan hub and ARGB Hub. It works smooth.
But, i still have 3 fans that came with cooler unused.
My question is can i connect two more fans in the top of the PC case and Daisy chain and connect with fan hub and ARGB Hub?
Will there be any impact on the performance or voltage? Can we connect 6 fans to one fan hub and one ARGB Hub by Daisy chaining all the fans?
I am using cooler master 650 V2 80+ gold power supply.
Lutfij
Might want to look into a ARGB and fan hub, akin to this;
but it's a PWM fan hub meaning hooking up 3 pin fans will result in the fans running at full speed. The ARGB would be managed off of one header that's on your motherboard.
The way I see it you might be able to manage your fans in your build with a hub like this;
https://www.phanteks.com/PH-PWHUB.html
or
https://phanteks.com/PH-PWHUB_02.html
since they will handle 3pin and 4pin fans with ease.
