Need help with basic batch file
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
I am trying to write a batch file that will open 3 programs on my hard
drive.
I am running Win XP home. Here's the batch file
::start.bat
::starts multiple programs
@echo off
"C:\Program Files\QuickVerse Sermon Builder 4\qvsb4.exe"
"C:\Program Files\PC Magazine Utilities\Winpointer\WinPointer.exe"
"C:\Program Files\WordPerfect Office 12\Programs\wpwin12.exe"
what happens is that it will load the first program but will not load the
second one until the first one is closed. When I close the second program
the 3rd program will then load.
How do I get all three to load at once?
G
Guest
Guest
start "" "C:\Program Files\QuickVerse Sermon Builder 4\qvsb4.exe"
start "" "C:\Program Files\PC Magazine Utilities\Winpointer\WinPointer.exe"
start "" "C:\Program Files\WordPerfect Office 12\Programs\wpwin12.exe"
Regards,
Dave Patrick ....Please no email replies - reply in newsgroup.
Microsoft Certified Professional
Microsoft MVP [Windows]
http://www.microsoft.com/protect
| drive.
| ::start.bat
| @echo off
G
Guest
Guest
Ah. I had tried the start in the batch but was not including the double
quote before the paht/program. thanks for that!
"Dave Patrick" <DSPatrick@nOsPAM.gmail.com> wrote in message
news:%23eLhKtosFHA.596@TK2MSFTNGP12.phx.gbl...
> Regards,
> | drive.
> | ::start.bat
> | @echo off
> the
> program
G
Guest
Guest
You're welcome.
Regards,
G
Guest
Guest
Type start in help.
http://webdiary.smh.com.au/archives/_comment/001075.html
"Brad Morris" <bradmorris@mchsi.com> wrote in message news:%23wtnScosFHA.1328@TK2MSFTNGP10.phx.gbl...
> drive.
> ::start.bat
> @echo off
G
Guest
Guest
On Mon, 5 Sep 2005 21:02:44 -0500 in
microsoft.public.windowsxp.general, Brad Morris favored us with...
You need the command START at the beginning of each line.
Stan Brown, Oak Road Systems, Tompkins County, New York, USA
http://OakRoadSystems.com/
"And if you're afraid of butter, which many people are nowa-
days, (long pause) you just put in cream." --Julia Child
G
Guest
Guest
On Tue, 6 Sep 2005 12:22:58 +1000 in
microsoft.public.windowsxp.general, favored us with...
> > drive.
> Type start in help.
You really ought to try your own advice before you post it.
Out of curiosity, I did type "start" (no quotes) in Help, and I got
15 topics, NOT ONE of which actually helped with the OP's question.
To get help on the START command, you need to search "command-line
reference" (no quotes, but you need the hyphen!), then select
Command-line reference A-Z
then select S and Start.
It seems unfortunate that one can't get help on a command by just
typing the command name in Help and Support. (Of course there's
"START /?" from the prompt, but that doesn't let you scroll back and
forth.) What I did, once I finally found "Command-line reference A-
Z", was to create a shortcut to it in my Start Menu. The shortcut
target is
%systemroot%\hh.exe Ms-its:%systemroot%\help\ntcmds.chm::/ntcmds.htm
G
Guest
Guest
Hi Stan, increase the screen buffer for CMD properties and then you can
scroll back and forth.
>>>drive.
>>Type start in help.
> target is
G
Guest
Guest
6th entry on the second tab.
"Stan Brown" <the_stan_brown@fastmail.fm> wrote in message news:MPG.1d88d0af4bddc0c2989715@news.individual.net...
>> > drive.
>> Type start in help.
> target is
G
Guest
Guest
On Thu, 8 Sep 2005 03:18:30 +1000 in
> >> Type start in help.
"Windows XP Product Activation Privacy Policy". Doesn't seem to have
a lot to do with the START command.
A: Maybe because some people are too annoyed by top-posting.
Q: Why do I not get an answer to my question(s)?
A: Because it messes up the order in which people normally read text.
Q: Why is top-posting such a bad thing?
