Im thinking about buying a bitfenix spectre pro 140 mm led fan. If you dont plug the fan Led cable to a separate connection the brightness will go down when you´re decreasing the voltage to lower the fans rpm. I want the LEDs to always be at their brightest but I dont understand where to connect the LED cable
My motherboard: Gigabyte GA Z87 UD3H
