Need help with boot issue (New Bulid)
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
ignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuff
ignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuff
ignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuffignore stuff
It could be not seated all the way. Make sure the four pins are fully pressed in and snapped into place. Also make sure your RAM is fully seated as well.
If neither of those two work, remove the power cables from the motherboard (24 pin and CPU power) and unplug the power supply, then remove the CMOS battery (looks like a big watch battery on the motherboard) for a couple of minutes, and try again.
I would say your PSU could be the fault. Swap it out for another and see what happens.
