Question Need help with BSOD 101 AND 124
May 15, 2019
I bought an used pc that was overclocked. It runs incredibly well for the price i payed, except for the constant BSOD.
GPU : Rx580 OC 1505 core clock, 1950 memory clock with afterburner
Cpu: i5 2500k OC 4.6ghz
Ram: ddr3 corsair dominator gt (1333 2x4gb i think)
MOBO: asus p8p67 pro
Windows 7 pro 64
The errros are always related to ntoskrnl.exe and hal.dll
I ran diagnosis test on HDD, SSD, CPU with the diagnosis programs by each of the brands, they all passed.
While playing, both cpu and gpu temperatures NEVER go above 60º Celsius, rarely go above 55º
Here is the MEM86test results:
Test Start Time2019-06-03 11:43:19
Elapsed Time1:59:24
Memory Range Tested0x0 - 21F000000 (8688MB)
CPU Selection ModeParallel (All CPUs)
ECC PollingEnabled
# Tests Passed46/48 (95%)
Lowest Error Address0x1BA8BF748 (7080MB)
Highest Error Address0x1BA8BF748 (7080MB)
Bits in Error Mask0000000000020000
Bits in Error1
Max Contiguous Errors1
Test# Tests PassedErrors
Test 0 [Address test, walking ones, 1 CPU]4/4 (100%)0
Test 1 [Address test, own address, 1 CPU]4/4 (100%)0
Test 2 [Address test, own address]4/4 (100%)0
Test 3 [Moving inversions, ones & zeroes]4/4 (100%)0
Test 4 [Moving inversions, 8-bit pattern]4/4 (100%)0
Test 5 [Moving inversions, random pattern]4/4 (100%)0
Test 6 [Block move, 64-byte blocks]4/4 (100%)0
Test 7 [Moving inversions, 32-bit pattern]4/4 (100%)0
Test 8 [Random number sequence]4/4 (100%)0
Test 9 [Modulo 20, ones & zeros]4/4 (100%)0
Test 10 [Bit fade test, 2 patterns, 1 CPU]2/4 (50%)2
Test 13 [Hammer test]4/4 (100%)0
Last 10 Errors
2019-06-03 12:28:40 - [Data Error] Test: 10, CPU: 0, Address: 1BA8BF748, Expected: 00000000, Actual: 00020000
And here is bluescreenview results:
Dump File : 053019-11871-01.dmp
Crash Time : 30-05-2019 19:41:13
Bug Check String :
Bug Check Code : 0x00000124
Parameter 1 : 0000000000000000 Parameter 2 : fffffa800720d028
Parameter 3 : 00000000be200000 Parameter 4 : 000000000005110a
Caused By Driver : hal.dll
Caused By Address : hal.dll+129ef
File Description : Hardware Abstraction Layer DLL
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 6.1.7601.24475 (win7sp1_ldr.190516-0600)
Processor : x64
Crash Address : ntoskrnl.exe+93aa0
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\053019-11871-01.dmp
Processors Count : 4
Major Version : 15
Minor Version : 7601
Dump File Size : 280.456
Dump File Time : 30-05-2019 19:42:07
Dump File : 060119-10748-01.dmp
Crash Time : 31-05-2019 17:05:21
Bug Check String :
Parameter 1 : 0000000000000000 Parameter 2 : fffffa800725e028
Caused By Driver :
Caused By Address :
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address :
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\060119-10748-01.dmp
Major Version : 15
Dump File Size : 262.144
Dump File Time : 01-06-2019 00:41:13
Dump File : 060319-11060-01.dmp
Crash Time : 03-06-2019 00:08:21
Bug Check String :
Bug Check Code : 0x00000101
Parameter 1 : 0000000000000031 Parameter 2 : 0000000000000000
Parameter 3 : fffff88003342180 Parameter 4 : 0000000000000002
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+93aa0
File Description : NT Kernel & System
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\060319-11060-01.dmp
Major Version : 15
Dump File Time : 03-06-2019 00:09:58
Dump File : 060319-12105-01.dmp
Crash Time : 03-06-2019 10:37:58
Bug Check String :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\060319-12105-01.dmp
Major Version : 15
Dump File Time : 03-06-2019 10:39:18
Dump File : 060819-13026-01.dmp
Crash Time : 08-06-2019 14:04:36
Bug Check String :
Parameter 1 : 0000000000000000 Parameter 2 : fffffa800721c028
Caused By Driver :
Caused By Address :
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address :
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\060819-13026-01.dmp
Major Version : 15
Dump File Time : 08-06-2019 14:05:32
Dump File : 061019-12090-01.dmp
Crash Time : 09-06-2019 23:54:11
Bug Check String :
Parameter 1 : 0000000000000000 Parameter 2 : fffffa800996e028
Caused By Driver :
Caused By Address :
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address :
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\061019-12090-01.dmp
Major Version : 15
Dump File Time : 10-06-2019 00:09:37
Dump File : 061319-12589-01.dmp
Crash Time : 13-06-2019 15:15:48
Bug Check String :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\061319-12589-01.dmp
Major Version : 15
Dump File Time : 13-06-2019 15:16:36
Dump File : 061719-11949-01.dmp
Crash Time : 17-06-2019 12:58:54
Bug Check String :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\061719-11949-01.dmp
Major Version : 15
Dump File Time : 17-06-2019 13:00:13
Dump File : 061719-11840-01.dmp
Crash Time : 17-06-2019 13:36:31
Bug Check String :
Parameter 1 : 0000000000000000 Parameter 2 : fffffa80071d7028
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\061719-11840-01.dmp
Major Version : 15
Dump File Time : 17-06-2019 13:37:40
Dump File : 061719-11403-01.dmp
Crash Time : 17-06-2019 14:55:39
Bug Check String :
Parameter 1 : 0000000000000000 Parameter 2 : fffffa8009980028
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\061719-11403-01.dmp
Major Version : 15
Dump File Size : 280.344
Dump File Time : 17-06-2019 17:05:02
Btw I manually updated every single driver from control panel and still have crashes.
So i guess it aint driver related
Ilijas Ramic
368
I think the cpu is not stable what voltage are you running for 4.6 ?
You still can downclock it to like 4.5 and see my guess is its not stable at 4.6
Im using 2600k i been running it 4.5 with 1.332v for like 1 year then it started to get bdos i need to add little more vcore to get it stable again. Did you formate the pc ? Maybe there is a malware corruption it usually ends with hal.dll bsod
