Need help with BSOD
RainetK22rma
4
Hello ,
for a few days now my computer has started to crash and gets BOSD. I am pretty sure the problem is with my RAM . But i have no idea how to troubleshoot the real problem.
System : Intel(R) Core(TM) i7-2600 CPU @ 3,40 GHz
16,0 GB of Ram (4x4 GB)
Win 8.1 64 Bit Operating system , x64- based processor
Graphics Card : amd Radeon R9 285
Mother board: DH67BL
I have some information of my previous BOSD:
Dump File
1. 032715-5265-01.dmp
2. 032715-5312-01.dmp
3. 032715-12015-01.dmp
4. 032515-6140-01.dmp
5. 032515-5125-01.dmp
Bug Check String
1. MEMORY_MANAGEMENT
2. MEMORY_MANAGEMENT
3. IRQL_NOT_LESS_OR_EQUAL
4. NTFS_FILE_SYSTEM
5. MEMORY_MANAGEMENT
Bug Check Code
1. 0x0000001a
2. 0x000000be
3. 0x0000000a
4. 0x00000024
5. 0x0000001a
Parameter 1
1. 00000000`00005002
2. fffff6bf`fc52dd80
3. ffffe001`87a3f2b0
4. 000000b5`00190637
5. 00000000`00041792
Parameter 2
1. fffff580`10804000
2. 0b800001`6ae1c025
3. 00000000`00000002
4. ffffd000`28577018
5. fffff680`00005040
Parameter 3
1. 00000000`000005c5
2. ffffd001`ca4c5fd0
3. 00000000`00000001
4. ffffd000`28576820
5. 00000600`00000000
Parameter 4
1. 0000205c`6ffffffe
2. 00000000`0000000b
3. fffff802`90e4230b
4. fffff802`ee76d9fd
5. 00000000`00000000
Caused By Driver
1. ntoskrnl.exe
2. WdFilter.sys
3. ntoskrnl.exe
4. Ntfs.sys
5. ntoskrnl.exe
Caused By Address
1. ntoskrnl.exe+1509a0
2. WdFilter.sys+232f4
3. ntoskrnl.exe+1509a0
4. Ntfs.sys+a9a5
5. ntoskrnl.exe+1509a0
If there is someone who has some time , i would appriciate your help.
Thank you for response.
To rule out hard drive issues ensure SMART drive monitoring is turned ON in the BIOS.
Also,
Run CHKDSK /r on your C drive. (Google it)
Lastly, download a boot-able drive diagnostic disc from the manufacturer of your hard drive (Most manufacturers have one you can use to test their drives for failures/issues)
If your fairly certain it the RAM then google memtest86. You'll burn a bootable DVD and load your computer from that disc and run a memory diagnostic for no less than 24 hrs. If the test fails or your computer reboots you might indeed have a RAM issue.
Hey , thank you for your answer . I already had SMART enabled.
And as much i know there is no need to run CHKDSK on your drive if your drive is an SSD .
And i am pretty sure the problem cant be in my drives, because i just bought new ones about 3 months ago. : My main drive:Samsung 840 EVO 250GB 2.5 inch Basic SATA Solid State Drive
Secondary Drive : WD 1TB SATA lll Desktop SATA Drive - Blue .
I still have to try out the last solution - memtest86 , but i cant do it before tomorrow.
most of the bugchecks were in memory management. I would focus finding the cause of those first and would assume the bugchecks in the filesystem are side effects caused by the memory management bugchecks.
Also, I would copy the actual memory .dmp files to a server and post a link. The error codes don't look like the ones you typically get with bad RAM.
you have a older CPU so I assume you have a older system. (ie blow dust out of the CPU fan, run hardware diagnostics)
Well maybe this is better:
Dump File : 032815-5218-01.dmp
Crash Time : 28.03.2015 15:56:37
Bug Check String : MEMORY_MANAGEMENT
Bug Check Code : 0x0000001a
Parameter 1 : 00000000`00041201
Parameter 2 : fffff680`001d3040
Parameter 3 : b9b02e02`2e286867
Parameter 4 : ffffe001`3259c230
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+1509a0
File Description : NT Kernel & System
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 6.3.9600.17668 (winblue_r8.150127-1500)
Processor : x64
Crash Address : ntoskrnl.exe+1509a0
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\032815-5218-01.dmp
Processors Count : 8
Major Version : 15
Minor Version : 9600
Dump File Size : 280 304
Dump File Time : 28.03.2015 15:57:08
Dump File : 032815-6281-01.dmp
Crash Time : 27.03.2015 23:55:32
Parameter 1 : 00000000`00041793
Parameter 2 : fffff680`003a3868
Parameter 3 : 00000000`00000007
Parameter 4 : 00000000`00000006
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\032815-6281-01.dmp
Major Version : 15
Dump File Time : 28.03.2015 15:44:52
Dump File : 032715-5203-01.dmp
Crash Time : 27.03.2015 23:38:46
Bug Check String : BAD_POOL_HEADER
Bug Check Code : 0x00000019
Parameter 1 : 00000000`0000000d
Parameter 2 : ffffc001`c4477ae0
Parameter 3 : 09763935`73270632
Parameter 4 : 09763b35`73270632
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\032715-5203-01.dmp
Major Version : 15
Dump File Time : 27.03.2015 23:39:17
Dump File : 032715-5281-01.dmp
Crash Time : 27.03.2015 23:12:51
Parameter 1 : 00000000`00041792
Parameter 2 : fffff680`526d4040
Parameter 3 : 00002600`00000000
Parameter 4 : 00000000`00000000
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\032715-5281-01.dmp
Major Version : 15
Dump File Time : 27.03.2015 23:13:23
Dump File : 032715-5031-01.dmp
Crash Time : 27.03.2015 22:23:36
Parameter 2 : fffff680`47f87040
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\032715-5031-01.dmp
Major Version : 15
Dump File Time : 27.03.2015 22:24:07
Dump File : 032715-5265-01.dmp
Crash Time : 27.03.2015 20:53:13
Parameter 1 : 00000000`00005002
Parameter 2 : fffff580`10804000
Parameter 3 : 00000000`000005c5
Parameter 4 : 0000205c`6ffffffe
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\032715-5265-01.dmp
Major Version : 15
Dump File Time : 27.03.2015 20:53:56
Dump File : 032715-5312-01.dmp
Crash Time : 27.03.2015 20:19:07
Bug Check String : ATTEMPTED_WRITE_TO_READONLY_MEMORY
Bug Check Code : 0x000000be
Parameter 1 : fffff6bf`fc52dd80
Parameter 2 : 0b800001`6ae1c025
Parameter 3 : ffffd001`ca4c5fd0
Parameter 4 : 00000000`0000000b
Caused By Driver : WdFilter.sys
Caused By Address : WdFilter.sys+232f4
File Description : Microsoft antimalware file system filter driver
Product Name : Microsoft Malware Protection
File Version : 4.7.0205.0
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\032715-5312-01.dmp
Major Version : 15
Dump File Time : 27.03.2015 20:19:39
Dump File : 032715-12015-01.dmp
Crash Time : 27.03.2015 19:56:53
Bug Check String : IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x0000000a
Parameter 1 : ffffe001`87a3f2b0
Parameter 2 : 00000000`00000002
Parameter 3 : 00000000`00000001
Parameter 4 : fffff802`90e4230b
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\032715-12015-01.dmp
Major Version : 15
Dump File Time : 27.03.2015 19:57:32
Dump File : 032515-6140-01.dmp
Crash Time : 25.03.2015 21:04:28
Bug Check String : NTFS_FILE_SYSTEM
Bug Check Code : 0x00000024
Parameter 1 : 000000b5`00190637
Parameter 2 : ffffd000`28577018
Parameter 3 : ffffd000`28576820
Parameter 4 : fffff802`ee76d9fd
Caused By Driver : Ntfs.sys
Caused By Address : Ntfs.sys+a9a5
File Description : NT File System Driver
File Version : 6.3.9600.17031 (winblue_gdr.140221-1952)
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\032515-6140-01.dmp
Major Version : 15
Dump File Time : 25.03.2015 21:05:02
Dump File : 032515-5125-01.dmp
Crash Time : 25.03.2015 21:00:39
Parameter 2 : fffff680`00005040
Parameter 3 : 00000600`00000000
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\032515-5125-01.dmp
Major Version : 15
Dump File Time : 25.03.2015 21:01:09
I should add that i get BSOD only when i try to run programs or games. I can run game fine , but if i have twitch stream open at the same time , one will crash , or i ll get BSOD. For example i cant run GW2 Or Photoshop anymore , while i have something else open. I didnˇt have this problem before.
I made memtest86 bootable flash drive and booted my pc from it , but i am not sure what it did. It started scan and ran for few hours checking my ram errors , but when it finished it didnt give me any report page or something like that.
