Need Help with BSODs
Wcd4541
40
Hey guys, starting today I have been getting BSODs for my custom build, and after searching the web for different solutions, it has become apparent that I cannot run any diagnostics without a BSOD restarting my computer. Luckily I have a laptop I can use until the problem is resolved, but my PC is only a year and a half old so I would like to try and find a way to fix it that doesn't involved dropping large amounts of cash on new parts.
Some of the errors I've been getting include:
MEMORY MANAGEMENT
IQRL NOT LESS THAN OR EQUAL TO
PAGE FAULT IN NON PAGED AREA
It boots up and runs for a little bit and then crashes, can you describe how to get the dmp files? I'll try to figure it out myself while I wait for your response.
It says I don't have access to those files, but I am an administrator so I should have access...
I figured it out!!!! I didn't know which files you wanted so I just included all of the ones that have been created in the past 24 hours.
https://1drv.ms/u/s!Avc6yasw_Obtg2yNsVuwL_dbP4XK
Thank you so much for your help so far! It's almost 1am here on the East Coast so I'm going to go to bed. I'll try to reply back to whatever you suggest tomorrow morning to continue working on the problem
I may have found the problem. After doing some searches online, I found a program called MemTest86 and downloaded it. It looks like one of my 8GB Corsair Vengeance RAM sticks went bad because I ran the test initially and a lot of errors came up, but then I removed one of the two and no errors showed up. I will post an update once the MemTest completely finishes to let you know if my problem was resolved.
