Hi all,
I see many incredibly helpful answers and advice here, which is why I'm posting here myself.
I'm looking to build a budget gaming pc build, primarily to play SWTOR. Now I have no plans to OC anything as I have no experience doing that, nor do I need to play everything on ultra high settings. That said, I've been looking at the following CPU and GPU:
AMD FX-6200 Zambezi 3.8GHz
SAPPHIRE 100366-2L Radeon R7 260X 2GB
I plan to reuse my old case, the hard drive and Corsair CX500 PSU (unless you think I should upgrade it). So my question is which motherboard would go well with this. Alternatively, if you guys have a better suggestion regarding the CPU and GPU, but in roughlythe same price range, I will be incredibly grateful (I'm something of a noob when it comes to selecting the parts...). My budget for the CPU, GPU, MOBO, and RAM (I need to buy that too) should hopefully not exceed 400 € (which is roughly 550 USD).
Any advice is much appreciated!
