Need Help With Building A new PC
Jan 6, 2015
5
Hello guys,
I`m going to buy a new pc and i`m wondering if i could use your suggestions :
My usage for PC is for GAMING and basic design apps like Photoshop and 3D MAX :
Here is my thoughts about it but i`m confusing about the components and honestly need your advises, if you please,
I`m from Egypt and my budged is 6500 or 6800 LE at MAXIMUM
here what iam thinking about,
MONITOR : Samsung Synsmaster 21.5 inch lcd led = 850 LE
NZXT 210 Mid Tower Case = 300 LE
Case : or
ZALMAN Z3 Mid Tower Case = 400 LE
GIGABYTE GA-B85-HD3 1150 = 800 LE ( I`ve used GB mobo for more than 18 years )
MoBo : or
ASUS B85-E socket 1150 = 750 LE ( I heard that Asus has a lot of respect too & it is the cheaper one for me either )
Seasonic 520 WT BRONZE = 520 LE ( I really like this PSU for its price and performance )
PSU : or
XFX TS Series 650W 80 Plus Bronze = 750 LE ( i heard that i`ll face problems if idon`t get one of those PSUs that Intel recommended for Haswell Cpus and it`s the cheapest one for me )
CPU : Core I5- 4590 but i`ll buy 4570 because the problem of BIOS Update = 1500 LE
MEMORY : Kingston HyperX Beast 8GB (2 X 4GB) DDR3 1600MHz CL9 1.65V = 650 LE
Western Digital (WD) Caviar BLUE 1TB SATA 6Gb/s 7200 RPM 64MB = 420 LE
HDD :
or
Seagate Barracuda ST1000DM003 1TB 7200 SATA = 420 LE
MSI HAWK 270X 2G DDR5 = 1600 LE ( NEW )
VGA : or
MSI HAWK GTX 760 2G DDR5 = 1600 LE ( USED )
or
GIGABYTE 280X 3G DDR5 = 1600 LE ( USED )
I`m really sorry for any language mistakes and apologies for being too long.
Thanks in advance
I think you should try to open up room for an I5-4690K because that CPU can be overlcocked (with a Z motherboard) which will help a ton in Photoshop and gaming, too.
Thanks for the fast reply, but i`m not interested in overclocking .
Also the I5-4670K is a bout 400 LE more than 15-4590 which force me to get a high motherboard for it and that would be impossible for my budged.
