Need help with building PC.
Oct 3, 2018
9
Is this build good and compatible?
https://pcpartpicker.com/list/BfFxWD
Since im not sure the one im going to buy is same like the one I chose on pcpartpicker here is the link for parts im thinking to buy:
Case is: https://www.amazon.de/gp/product/B01LYCLACO/ref=ox_sc_act_title_1_1_3?smid=A133RA3ZUAU4I7&psc=1]
And GPU is: https://www.amazon.de/gp/product/B071Y7XJY4/ref=ox_sc_act_title_1_1_7?smid=A3JWKAKR8XB7XF&psc=1]
Motherboard is: https://www.amazon.de/gp/product/B06X9LN311/ref=ox_sc_act_title_1_1_8?smid=A3JWKAKR8XB7XF&psc=1]
Also do you have any recommendations?
Fell free to give some advices since it is my first time I try to build any PC 😀 I have no knowledge about PC building. I always purchased laptops for playing games so far.
Tnx guys.
This looks better already. B450 board will have better memory compatibility and fewer issues than B350. Better overclocking too. X470 would be even better, depending on the model, but I don't really know what kind of budget you have to work with so I'm trying to stay in the same approximate bracket you were already in.
CPU: AMD - Ryzen 5 1600X 3.6GHz 6-Core Processor (€156.68 @ Mindfactory)
CPU Cooler: Corsair - H115i PRO 55.4 CFM Liquid CPU Cooler (€133.44 @ Amazon Deutschland)
Motherboard: Asus - PRIME B450-PLUS ATX AM4 Motherboard (€104.90 @ Caseking)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB)...
When it comes to the case, you can get way better than that. At that pricepoint, the Phanteks Evolv series has some great options.
The motherboard is also lacking. I'd get one with a different chipset so you can overclock that X processor of yours and take advantage of that liquid cooling.
Power supply is waaaaay to pricey. A $140 USD pricetag for a gold rated model is just... No. If you want to spend that much on it, which I don't recommend in any way shape or form unless you're on the really high end, which you're not, aim for a full modular platinum rated one like this: https://pcpartpicker.com/product/jBZ2FT/evga-power-supply-220p20750x1
And on that note, I really hope your intention with this build is to leave room for upgradability, because you can get basically the same performance as this for way cheaper. If upgradability is your goal, though, you're at least thinking the right things, just keep in mind what I suggested.
What country are you actually in? You realize PCPP has 14 different country options you can choose from at the top right of the screen on any page?
Which of those is closest to your or is applicable? For example, some of the items on your US based PCPP build are not available when I switch that build to deutschland or Netherlands, while others are but even others are not on the UK filter.
You are basing ALL of what you are saying here on the idea that the OP is from the US and that parts prices and availability in his country are the same. I assure you, they are not. He was only providing the PCPP list as a guide, not as a representation of his cost on parts. In his country, that RMx PSU might be the best price on a gold unit and may not be anything similar in price comparison as what you'd find in the US.
Tnx man. Yes, I want to upgrade in early 2019 (april cca) since Im getting a really good job.
So...only to change power supply? 😀
And like Darkbreeze say im from Austria and buying mostly from Germany since shipment is mostly free...and yes, prices are wery different...that case is like 160eur here. And motherboard is 85eur. PSU is 110 eur.
BTW didnt expect so fast reply 😀
Okay, just make sure the prices I mentioned all apply where you are. Kudos to Darkbreeze for catching me on that.
Not really...I just noticed (or supposed) it would fit good with other parts.
And price is 277eur plus found "good" monitor with free sync in half price on action.
I mean, my budget would be like 1600eur with monitor, keyboard, mouse, all hardware etc...
Just noticed that freesyinc monitors and AMD are bit cheaper that nvidia so I build something from "that side"...but I have no real preference about anything except playing games ahhaha
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory (€142.89 @ Alternate)
Storage: Samsung - 860 Evo 500GB 2.5" Solid State Drive (€85.00 @ Amazon Deutschland)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive (€58.55 @ Amazon Deutschland)
Video Card: Gigabyte - Radeon RX 580 8GB Gaming 8G Video Card (€277.99 @ Amazon Deutschland)
Power Supply: SeaSonic - FOCUS Plus Gold 750W 80+ Gold Certified Fully-Modular ATX Power Supply (€103.83 @ Amazon Deutschland)
Total: €1063.28
Generated by PCPartPicker 2018-10-04 00:12 CEST+0200
Cases are highly subjective, aside from basic features which most all high end models have these days. I think if you stick to cases over 80 bucks from Fractal design, NZXT, Phanteks or Corsair you'll end up with a good unit. The rest are all pretty much hit or miss. They have good and bad models at all price ranges.
Gigabyte X470 Aorus Ultra Gaming I can buy for 139eur...so maybe to buy that one?
No. I really don't. But then again I don't care for Cooler Master as a company at all really. I've owned several Cooler Master cases, currently I have a Storm enforcer and Masterbox lite sitting on the shelf. The Storm enforcer was halfway decent for it's time, but even then it lacked a lock of features and was a bit flimsier than some others I could have purchased.
Honestly, at just about any price point, there are better cases to be had than any competing CM case, and usually AS good for less.
This is case is a lot less expensive than what you are talking about and is currently one of the very best cases you could buy at any price. If you want RGB and lighting badly, then buy dedicated lighting like the NZXT Hue+ or something similar. This case is five times better than that CM pile of bolts, IMO. I'm sure somebody else will disagree, but overall Cooler master sucks when it comes to support, quality and performance. The only thing they have going for them right now is innovation in the modularity aspect of the case, which to me, is wasted and unnecessary anyhow. Nothing needs to come apart that much unless you have some kind of mental condition or you're a tweaker and constantly taking it apart.
Most people won't have their system entirely apart more than a handful of times in it's entire life, so those exploded views look nice on a website but they are really practically useless.
Case: Fractal Design - Define R6 Black TG ATX Mid Tower Case (€135.85 @ Amazon Deutschland)
Total: €135.85
Generated by PCPartPicker 2018-10-04 07:33 CEST+0200
You ARE wanting a mid tower case, not a FULL tower, right? Full tower is huge, like the Phanteks Enthoo Pro.
Latest posts
