Need help with case cooling in a Thermaltake Core V1.
2456apple
Commendable
Sep 20, 2016
I have a Thermaltake Core V1 and a Corsair H80i v2. I don't know if the H80i will fit into the case due to the thick radiator. The other issue I have is with the 200mm fan in the front of the case. Should I keep that in the case and use the H80i in a pull configuration or remove the fan and use a push/pull config? Or should I look for another cooler for my PC.
Config
Intel i7 6700k
Evga Z170 stinger
Evga Superclocked DDR4 2400
Evga GTX 1080 Founder's edition
Evga 750W BQ Semi-modular PSU
Thermaltake Core V1
Corsair H80i v2
Toshiba x300 6TB HDD
Sandisk SSD 240GB
I'd say to go for removing the front 200mm fan and go for a push/pull with the H80i v2
^ read more here.
