Hi to everyone. I need some assistance. In the next week or so I want to clean my computer case and maybe to rearrange my case fans. Currently, I have 3 case fans, one in the front, one in the rear and one at the top near the middle spot. Two are exhaust fans and one in the front is intake fan. Also, my air cooler is positioned from front of the case to rear and my PSU is at the bottom and facing down.
So, what do you all think? Is this good configuration or maybe I need to reposition them? Maybe CPU cooler facing from bottom to top instead from front to back? O, and my case is located on the wooden floor under my desk. Thanks all in advance.
p.s. Top rear spot in the case is unusable due to the 8-pin CPU cable interference.
My PC specs:
My PC specs:
Case - Cooler Master Elite 430
Case fans - Fractal Design Silent Series R2 140mm (front intake),
Fractal Design Silent Series R2 120mm (rear exhaust),
Fractal Design Silent Series R2 120mm (top exhaust)
Motherboard - Asus M5A99 FX PRO R2.0
PSU - Cooler Master V550
CPU - AMD FX 8320 @ 4GHz
CPU Cooler - CM Hyper 212 EVO
GPU - Gigabyte R9 380 4GB G1 Gaming (stock)
1 SSD
1 HDD
1 SSD
1 HDD
