I have CM storm stryker installed with nzxt kraken x61 and gigabyte gtx980ti xtreme waterforce radiator.
The case have space for coolig fan :-
Front: 120mm x2
Top: 200mm x1
Rear: 140mm x1
Bottom: 120mm x2
With one 280mm and one 120mm radiator, I have top and rear occupied and that left only the front 120mm x 2 fans doing the air circulation work. My PC is placed on the floor due to limit of space so it seems useless for installing the bottom fans.
Whenever the gpu and cpu are on loads, the casing gets quite warm with lots of hot air. The GPU temp will go up to 65 celcius and cpu 45 celcius when play certain high demand games.
I have to take off the side panel and get a fan to blow away the hot air.
What can I do to improve the air circulation of the casing?
Front: 120mm x2
Top: 200mm x1
Rear: 140mm x1
Bottom: 120mm x2
