Hello all i was wondering if the GTX 770 will fit in my PC case ill link the spec's here:
Mini-tower
Height: 41.3 cm (16.26 inches)
Width: 17.3 cm (6.85 inches)
Length: 42.4 cm (16.73 inches)
Weight: 12 Kg (26.46 lbs) - without packaging
Bay size
13.33 cm (5.25 inch) ODD
8.89 cm (3.5 inch) HDD
The graphics card i am thinking of buying is http://www.macotechnology.com.au/pd9.asp?cat=Video%20Card&pd1=1&pd2=nVidia%20GTX770&pid=4266
if that card does not fit any suggestions about a new graphics card need to be around $400 (australian).
Thank you in advance for any help
Mini-tower
Bay size
