Question Need help with choosing between 4 builds
Pankaj12325
73
4
4,545
PROCESSORAMD Ryzen 5 4600G 3.7GHz Processor13500
MOTHERBOARDASROCK A320M-HDV R4.0 MOTHERBOARD3480
PSUANT ESPORTS VS400L1200
RAMG.Skill F4-3200C16D-16GVKB Desktop Ram Ripjaws V Series 16GB (8GBx2) DDR4 3200MHz Black5715
MOTHERBOARDASRock B450M-HDV R4.0 Motherboard (AMD Socket AM4/Ryzen Series CPU/Max 32GB DDR4 3200MHz Memory)4870
PSUCorsair CX550M SMPS - 550 Watt 80 Plus Bronze Certification Semi Modular PSU4075
RAMADATA XPG Gammix D30 Series 8GB (8GBX1) DDR4 3200MHz RAM AX4U32008G16A-SR302399
TOTAL24854
ProcessorAMD Ryzen 5 5600G 6 Core Processor18000
MotherboardASROCK A320M-HDV R4.0 MOTHERBOARD3480
TOTAL25079
PROCESSORAMD Ryzen 3 PRO 4350G 3.8GHz Processor (This is OEM part)10999
TOTAL25659
EDITS in builds are also appreciated. Region is India
I am building this for light gaming.
I have 720p monitor, SSD, HDD and other peripherals. Only 4 this parts are needed to upgrade. I am student and I will need this for programming too.
I have no plans for GPU in next 3-4 years.
I have also reviewed YouTube gameplay and somehow ryzen 4350 gives more fps (20% more) having less core as well threads, less high clock speed, less GPU cores (6 vs 7 running at 1700 vs 1900)
4350g has everything lower than 4600g but how it still gives more fps? Can anyone explain this please?
Games I would like to play: Genshin Impact, and newer assassin creed titles. I won't mind lower fps, 30fps 720p is acceptable to me
In your four posted builds, I prefer the last one.
Second build would be ideal with dual channel memory.
All off the shelf parts except the CPU, and dual channel memory. Those two builds with single channel memory, absolutely not. Integrated graphics need as much memory bandwidth as possible, going single channel is a huge problem.
I don't trust the ANT Esports PSU.
Hard to say with the videos doesn't seem like they have the build details posted. The varying performance could be down to background tasks or simply temperature. How consistently they applied the CPU cooler (or if they were using one that was inadequate for the faster chips, giving an edge to the lower end ones that could stay cooler)
in single channel memory builds, I plan to upgrade to dual channel later down the line, would take few months. My goal would be getting atleast 16gb Ram. The last build processor is OEM, do they support warranty?
If i will get another 8gb stick, should i choose 2nd build?
