Hello all,
I'm looking to put together a new pc.
Specs are:
i7 965
Asus X58 mobo. haven't chosen yet
2 GTX 285
2 Crucial m225 128gb raid
2 500gb HD
6gb ram
1000W PSU
I currently have the Antec 900 & with so many fans in the case I have to clean it every 3-4 months. It really is a nightmare to deal with.
So I want a new case. I'm willing to invest up to $300 for a case that has these specs:
-Full tower size case.
-3 120mm or 140mm front fans with filters
-2 120mm in the rear 1x200 or 2 x 140mm top extraction fans.
-1 side door fan optional.
-I need room for 3 optical drives 5.25"
-A lot of space between the motherboard and HD rack to fit the widest card available (so it's easier to slip in and deal with sata /power cords as well without being too constrained)
-Enough space below and above MB area for better cable routing from the back to the MB be it USB audio 1394 and power/reset/hdd light. The Antec 900 is too tight for this.
-cable for power reset HDD need to be longer than the short length by the Antec 900.
-PSU at bottom.
-140mm fan width case would be better so I can slide the MB & TRUE120 without problems. It's hard to do it with the 900.
-MB/HD tray not needed.
-no thumb/screws to remove side doors. QR a must. Is it possible to have the side door(removable) on a hinge?
-black matte paint inside semi gloss out.
-front connections 4 USB 3.0/esata/audio~mic/1394- no door
-I have no problem with the noise of all the fans.
-Cable management. enough room behind 2nd door.
-No Antec cases anymore. No coolermaster. Maybe Lian li.
Ports for cable management:
-top small port left behind MB for 12v cable from the back
-3 small ports running the bottom of the MB for audio/USB/1394/power~reset~HDD
-3 ports to the right of MB for routing cable be it sata/ power/fans
-1 port to the right of the PSU for excess cords. Not like Antec's diagonal port which looks horrible.
Specs are:
i7 965
2 GTX 285
2 500gb HD
6gb ram
1000W PSU
-PSU at bottom.
