Need help with choosing motherboards
shayaanfacebook
Commendable
Oct 26, 2017
56
Hi there,
I will be buying a i7-8700k and I understand that these CPU's only fit on motherboards which have a LGA1151 socket. However, do different 1151 motherboards provide different benefits?
Please see this link: https://www.pcspecialist.co.uk/computers/intel-z370-pc/
When I change the motherboard from ASUS PRIME Z370-P to ASUS ROG STRIX Z370-H GAMING, the price of the overall PC increases by nearly £100?? What is the difference between these two motherboards (the expensive and cheaper)? Do they at all affect the PC's performance and is it worth getting? I will be gaming/streaming on this PC, and will be using a 1080ti with this build, if that at all helps.
But yeah, it would be nice to save £100 if I knew the upgrade in motherboard is not significant or wouldn't affect the PC's performance.
Thanks as always!
The Price difference between the two should be only 40 euros in Europe. no way 100 pounds.
in UK
https://www.aria.co.uk/Products/Components/Motherboards/Intel+Socket/Socket+1151+-+Intel+Z370/ASUS+ROG+STRIX+Z370-H+GAMING+-+Intel+Coffee+Lake+Motherboard?productId=68629&utm_source=skinflint.co.uk&utm_medium=referral
https://www.aria.co.uk/Products/Components/Motherboards/Intel+Socket/Socket+1151+-+Intel+Z370/ASUS+PRIME+Z370-P+-+Intel+Coffee+Lake+Motherboard?productId=68632&utm_source=skinflint.co.uk&utm_medium=referral
Here are the differencs between the two :
1- Slots :
The Prime :
2x PCIe 3.0 x16 (1x x16, 1x x4), 4x PCIe 3.0 x1, 2x M.2/​M-Key
The Strix :
3x PCIe 3.0 x16 (1x x16, 1x x8, 1x x2), 3x PCIe 3.0 x1, 1x M.2/​M-Key...
in UK
1- Slots :
The Prime :
The Strix :
3x PCIe 3.0 x16 (1x x16, 1x x8, 1x x2), 3x PCIe 3.0 x1, 1x M.2/​M-Key (PCIe 3.0 x4/​SATA) 1x M.2/​M-Key (PCIe 3.0 x4, 2280/​2260/​2242)
2- Sound
The Prime :
7.1 Realtek ALC887
The Strix :
7.1 Realtek ALC1220/​SupremeFX
3- Multi GPU
The Prime : NO SLI , only Cross Fire
The Strix : 2 ways SLI and CF
4- USB :
The Prime : No USB 3.1
The Strix : USB 3.1
5- Lan :
The Prime : Realtek LAN chip
Strix : Intel Lan Chip
6- Audio Jacks :
Prime : 3 and no digital .
Strix : 5 with Digital
7- SATA3 :
Prime : 4
Strix : 6
Summary : Get the Strix .
Wow that couldn't have been more clearer, thank you for this!!!
