Need help with choosing right cooler for r5 1600 3.7ghz oc
genca
436
Hi, i want to buy new cooler for my r5 because stock cooler is loud for me. Here are cooler that i chose and dont recommend me any other please! Sorry for bad English
First: Be Quiet Pure Rock
Second: RAIJINTEK Leto PRO Black white LED
Third: COOLERMASTER Hyper MA410P RGB led
Now, i read that pure rock might block 1 ram slot, and that will be problem because i will upgrade to 16gb ram soon. Other two, i also read that they are a little loud, but they are beautiful. As title says, i will use cooler for r5 1600 that will be oc to 3.7ghz and no more. Ram hyperx predator 2x4 3000mhz, b350-f strix, nzxt s340 black.
Cryorig H7. Better than the choices, one of the best mounting systems, only 145mm tall so will fit most ATX mid/mini towers and has an offset design with 0 ram clearance issues. The Quad Lumi is an upgraded version with RGB lighting and dual fans.
As I said, please dont recommend me other options.... i knew someone would tell cryorig or scythe but in Serbia and Hungary no1 is selling them.... Could you help me with this options i mentioned above? How loud this coolers with rgb are?
With a lot of luck, i found them in hungary. Now, here is what i can pick( but still dont know price but nvm) : Scythe Fuma, Scythe Mugen 5 and Cryorig H7, quad lumi. Now, which one of these is most quiet. I dont really care about 1-3 degrees difference between coolers, i just need the most quiet cooler( i have some problems with ears...caused my intel stock cooler....). I would try to avoid cryorig h7 bcs of white fan. However, i will wait for your reply and then ill make my decision.
