G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
I have a little problem with Windows 2000 and the K-Lite Mega codec
pack 1.01
I uninstalled the previous pack 2.20, upgraded to Media Player 9, then
installed the new pack with playback only config, but now all AVI and
OGM videos show only some horizontal lines. 🙁(((
This happens with any player. I tried to uninstall and reinstall
several times with different options, but nothing changes. The codec
pack works fine on another virgin Windows installation, there is
nothing wrong with the codecs. It looks more like an issue with the
avi splitter or the directshow video renderer.
How can I check if all components are in the right place?
I had a look at the Drivers.desc and Drivers32 registry key, but I
think there are a lot more places to check.
I don't really need multimedia support on this PC (it's used mainly as
a firewall and proxy server), but it's very annoying when things won't
work as they are supposed to. 🙁
Thank you for help,
TheLuke
pack 1.01
Thank you for help,
TheLuke
