Need help with colour temperature settings of the Samsung S24D340H
Esrevinue
Commendable
Mar 24, 2016
4
Hello!
I need some help with my monitor, the Samsung S24D340h, which I got a few months ago. I recently noticed that my display settings may not exactly be calibrated properly (In regards to colour correction, gamma, etc.) after messing with some settings that made some details appear more vividly. I have found a calibration test on the site http://www.lagom.nl/lcd-test/ and before I started I noticed that the site said I should adjust the colour temperature of my monitor before I went ahead did the tests. It also said that I should probably have the colour temperature around 6500K. There are two problems here:
1: I have no idea how to convert colour temperature to RGB
2: My monitor's RGB balancing is a confusing "Out of 100" scale, where the closer a colour is to 100, the more of it will appear on the screen. The "normal" preset for the colour balance is 50/100 for every colour.
I would appreciate it if someone could tell me a very good colour balance that will get me close to 6500K. Thanks for reading!
My GPU:
GTX 960 4GB
My CPU:
Intel Core i-7 870 @ 2.93 GHZ
Color temperature to 6500k? That's hilariously inaccurate.
Best you can do right now is to enable the Cinema/Movie/Theater preset in the picture preset menu, in your monitor's OSD. After that, use Windows built in calibration tool, by simply searching for it on disk, and follow the on screen instructions.
Thanks for this! This really made the difference!
