Need help with compatibility :D
spazattack23
Hey guys, I have always been an xbox gamer and recently have wanted to get into pc gaming. I'm looking into building a rig and know somewhat about hardware but could use some help before blowing money, I just need to know if what I have picked is compatible and what else I should buy that would be compatible. I am currently looking at a:
--Corsair Obsidian 350d mATX (Case)
--ASUS MAXIMUS VI GENE LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard (Motherboard)
--Vengeance 4GB dual channel DDR3 memory (Ram)
--AX760 ATX (PSU)
So now I need to choose a CPU and GPU, I'm looking to spend around 150-200$ per item. I like to game but don't need the HIGHEST end graphics card..
thanks guys!
There's no need to get a motherboard that expensive.
You could give us your budget and we could come up with a recommendation for a whole build? :)
Which parts? you said corsair are you talking about gpu and psu?
The PSU and the two Mobos
Look down the page, the post by Dino22, it's an official fix from Gigabyte to make the PSU compatible with the mobos. It's a resistor that causes it
http://forums.overclockers.com.au/showthread.php?t=1092284&page=2
I popped that damn graphite micro resistor myself and fixed it 😛
Yeah I was just looking at that motherboard because it had the color scheme that I wanted and also had plenty of ports, if you can find a motherboard that is intel and red/black color scheme for cheap that'd be great. I only plan on one PCIe slot and I want 4 DDR3 ram slots, besides that i think that's it. As far as budget goes, I'd like to keep the whole build under 1,000$
