Need help with compatibility for new graphics card
greencowking
11
I currently have a MSI Radeon R7 250 and I can barely play Fortnite on all low with 30 fps so I am trying to buy a new graphics card like a r9 270X but I dont know if it will be compatible with my computer and I need to know before I buy and replace can someone help me
If your PC is fine with the R7-250, it will be fine with the R9-270X (as long as the PSU is up to the task). Or probably any other card.
Btw, it's always important to list your system specs when you ask for that kind of advise.
Sorry here are the pictures of my specs I know the case is fine and the motherboard should be fine
https://imgur.com/gallery/3tKWGvx
Also here is the motherboard
https://imgur.com/B7gOBx7
Also my power supply is 350W do I need to get a new power supply as well to support the R9 270X
Yes, you'll need to replace the PSU if you go with the R9-270X. A 500W or better with 2 x 6-pin PCIe connectors. It's actually the +12v rail of the PSU that will determine the ability of a PSU to handle the card, tho.
Unless you're getting the R9-270X at a really good price, the 4GB GTX 1050 Ti would be a better choice. Faster than the 270X in most games and runs fine on your existing 350W PSU. Btw, what is the make/model of the 350W PSU?
https://imgur.com/Vyf5QDz Here is the sticker on my PSU and also this computer was bought from best buy and im just trying to upgrade the GPU because I can barely play games so can I change from AMD to NVIDIA if it is storebought sorry if I sound like a noob lol because I kind of am
