Cpu - Ryzen 3 1200
Mb - GIGABYTE GA-AB350M-Gaming 3 micro-atx
Psu - bequiet system power 9 500w
Gpu - sapphire itx rx 570 4gb
Case - Thermaltake versa h15 micro-atx (no window)
Hdd - 1tb wd
some additional fans and molex to 3-pin adapter.
So i chose GIGABYTE GA-AB350M-Gaming 3 motherboard because it is 10-15euros cheaper than asrock ab350m pro4 or different board but it is basically the same. And i checked the memory qvl (http://download.gigabyte.eu/FileList/Memory/mb_memory_ga-ab350m-gaming3.pdf) and it says that these - https://www.1a.lt/kompiuteriu_komponentai_tinklo_produktai/atmintis_hdd_ir_ssd/ram_atmintis/kingston_8gb_2666mhz_ddr4_cl15_hyperx_fury_black_kit_of_2_hx426c15fbk28 work on this motherboard but if we go to kingston site and look at the memory compatibility - (https://media.kingston.com/pdfs/hx-product-memory-ddr4-amd-ryzen-and-hx-compatibility-us.pdf) it is not there. Will these ram work? Or this kingston memory compatibility to ryzen pdf is outdated?
Hdd - 1tb wd
