Need help with component compatibility
Darkhowy
So, this is my first time building a computer and i'm wondering if these components are compatible and if they will serve me well in the future. I plan on using this build for mostly playing mmos and other rpg-style games.
Motherboard: MSI H81-E33
http://pcpartpicker.com/part/msi-motherboard-h81me33
CPU: Intel Pentium G3258
http://pcpartpicker.com/part/intel-cpu-bx80646g3258
Ram: CRucial Ballistix Sport 4GB
http://pcpartpicker.com/part/crucial-memory-bls4g3d1609ds1s00
Storage: Western Digital Caviar Blue 1TB HDD
http://pcpartpicker.com/part/western-digital-internal-hard-drive-wd10ezex
Case: NZXT Source 210
http://pcpartpicker.com/part/nzxt-case-s210001
Power Supply: EVGA 500w 80+ Bronze Certified
http://pcpartpicker.com/part/evga-power-supply-100b10500kr
Also, I will be using the integrated graphics until the gtx 960 comes out, if that helps
With the integrated graphics,you wont be able to play games smooth,even on the lowest possible,unless you play 4 years old games...
I recommend you buy some other graphics card,the gtx 960 wont be a revolution after all!
