Hello guys, so recently I’ve bought an core i7 for my p7h55-m motherboard, it currently has an core i5 650 with it. So when I receive the cpu I took apart my motherboard and installed my cpu excited to turn it on, unfortunately something came up that ruined my day, so as I press the power button my motherboard started to smoke around my main atx power plug ,and from it these weird copper tracks came off, and yes it did smoke cause I saw it and I smelt it. So later on I’ve bought an replacement for my motherboard luckily my other components survived, And here’s the point, if I install the core i7 again with the replacement will it happen again? I even double check at ASUS support and it said that my motherboard can support it
Specs
ASUS cg5275
P7H55-M motherboard
Core i5 650 3.20 ghz 73TPD
Core i7 870 2.93 ghz 95TPD (upgrade^)
4gb ram ASINT ddr3 1333mhz
Insignia power supply 450watts 80plus white
Samsung evo 850 250gb
Gtx 1050 gigabyte (non oc)
Specs
ASUS cg5275
P7H55-M motherboard
