Need Help with CPU fan/heatsink purchase...
jbrels76
20
Hi All,
Well I put together my system a week ago to find out that I can't install my new Zalmon CPU fan because the clamp could not fit within all of the heatsinks surrounding the CPU on the motherboard I have.
I currently am using a:
Asus Rampage Formula mobo (tons of heatsinks all around the CPU)
Antec 900 Case.
Zalmon 9700 (This is the fan I had purchased but can't install without jacking up one of the heatsinks about the CPU)
Does anyone iwth this setup, or atleast with this motherboard have any suggestions on some CPU fans I could check out. This Zalmon one will just not fit without tearing up one of the motherboard heatsinks, which I would rather not do. I would prefer one that has the mount that I can screw into the other side of the motherboard. Those push pin cpu fans are horrible.
-Thanks guys
I have a Rampage Formula and an Antec 900 case. I used a TRUE, but depending on how far you overclock, you can also use a standard Thermalright Ultra or even a Thermalright Ultra 90 for a bit less money and a bit more case clearance.
I have the same mobo
Installed TRUE wit no hassle
Mine needed lapping
Cooling fan Scythe s-flex sff21f
Look at my sig
